fourwinnsdook
- Jun 12, 2007
- 176
I have an 86 OMC 4.3L. Last night i changed out the shift cable with no problems at all. had the outdrive off and new cable in in less than an hour. After lining everything up i tried to put the outdrive back on, and it WILL NOT go on. It's getting cought up at that rubber boot that it has to go through. Has anyone else had this problem? Why is it soo tight there? it only passes through it doesn't even seal there. I tried for about two hours. Nothing.... i pushed it in soo hard i could see the rubber boot starting to come off. What's the deal?Please help!
