1992 60hp mariner - high throttle stalls - help?
Just today, I started my 60hp mariner outboard, ran rough and then when I use the high throttle, it stalls. I can only run at low speed.
The outboard runs on high idle, low idle it runs rough and dies.
I took the carburetor apart, both didn't show any sediment. Although, the bottom carb's bowl didn't have any gas. It looked somewhat dry. The top carb'd bowl had fuel in it.
I checked around and didn't see anything obvious.
I changed the spark plugs. I am not sure what to do next?
I will clean it with carb. cleaner tomorrow.
