Finially convinced a buddy to join the boating world. We tested a boat out and bought it. NOw that we have done some play with it on the water , a problem has developed. The boat keeps stalling in the lower rpm stages. You can be going at a steady slow speed and it will just die, or any sudden change in throttle position will cause it to stall. Exhaust showes no smoke, so not flooding right. I suspect the boat needs a proper water seperator, and a faulty fuel pump. Would it not stall at high rpm if fuel pump was bad. Appears it now has an automotive in-line filter now.Anything else to look at on carberator? It seems to start best with no extra throttle, just in nutral, but will often die before underway again. It is a '90 4.3 v-6 carberated? Help!
