Re: 1969 55HP Evinrude trouble after carb rebuild
So it's his fault the motor is running backwards? Carbs have nothing to do with that. Ignition has everything to do with that. There's a clip around the crankshaft that kills the ignition if the motor even tries to run backwards. It ain't there or it's slipped out of alignment. It's under the flywheel, nowhere near the carbs. There are two sets of points and a greased wick that lubricates the cam. The wick dried out, the rubbing blocks on the points wore down, the points gaps closed to next to nothing, the timing was thrown out of wack. Now it's quite possible that those carbs needed cleaning, I wouldn't be at all suprised. But cleaning them made the motor run which caused the points to wear which threw the timing off which made the motor run backwards which shouldn't have happened because there's a third thing wrong with it. These outboards in particular are downright peculiar and few understand them. Nothing familiarizes a mechanic more than owning one of these wacky things. I'm on my second. First was a 60, now a 100. I get them cheap.
There's an automatic half-choke that you need to disable. There's a thermoswitch left and low on the head. Clip either wire (purple/yellow) and tape the ends. That should handle the excessive smoking and some of the poor running characteristics. That feature never was worth a sh**!
Don't count that amplifier out quite yet. Address the stuff under the flywheel first. Be very careful of the distributor, they break with little provocation.
