I was looking at buying a 75 evinrude 40 hp, when I went to look at it I realized that it was a long shaft. I have heard about some motors that had a section you could remove to make it a short shaft. Could this be one of them? If so, is it hard to convert. Is there a drive shaft link, or do I need a whole different shaft that is shorter if this is even possible. The model number is 40555 c and there is a serial number of J0001839. Any help would be appreciated!
Re: 1975 evinrude 40 hp Is it a long and short shaft?
Thanks! That is good news. Now all I have to do is find some parts. I have this guy talked into selling me the motor for $250 so it might be worth it because I need a short shaft and this is both! Or I could leave it how it is and build up my transom 5" higher, right?
depending what you want to do you can easily build up your transom to accept a long shaft.we did it with a 40 yamaha to a starcraft aluminium boat in about a half to 1 hour using angle and flat bar and it has lasted years.
So I will need a shorter drive shaft and a shift rod. What about the water tube. I have never taken off a lower unit from an evinrude, only mercs and tohatsu's so I don't know what is there. I would guess about the same, so would I need a shorter water tube also?
