1993 Mariner Trim motor Hydraulic oil fill....
Hey all,
I am trying to get the right procedure for filling the trim motor with hydraulic oil. Should you take out the upper screw/knob and inject the fluid into the lower "release" screw until the fluid runs out of the opper screw, then tighten the upper to create vacuum and then tighten the lower screw?
Help!
