Re: Batery charging 115 yamaha 115ETLJ
Ok I tested it like i said and when the motor is off the battery tested at something like 12.87. When i start the motor it slowly goes to about 13.88 or something in that range. So i figure thats a good thing! Now i understand Jammer that most people have a gauge for that and i do its just that im installing this motor on this boat for the first time. I have the tach working and the trim gauge working but i dont know what these wires that are coming off the controll box are. If someone could please help me out with that! I have a volt gauge to install on the dash its not a yamaha one though. And i need to know what the wires in the picture that come off of the controll box are for. I have to plug in a green and a black to the tach to get that gauge to work and the same for the tilt gauge. Im wondering if there are wires that come out of the control box (in the picture) can charge a second battery? The wires from left to right in the picture are: YELLOW, GREEN, BLACK, PINK, BLACK, DOUBLE YELLOW. I know that i need to have 12v leads somewhere to run all the accessories that im going to install into the dash. By the way im starting over with the dash as in its new and carpeted. So what i need to know is how to run the wiring for my accessories that im going to install. Now i know that the battery is charging at least where the battery hooks up at the back of the boat. One of my questions is: is that the only place where the motor will charge a battery?? When i have the motor off and i turn the key to the "on" position i tested some of the wires coming out of the control box and some of them are getting 12 volts. I just really need to know what each wire is supposed to be for. Thanks again guys so far you have answered all my questions!!
