MercMonster
- Jun 3, 2007
- 151
Have finally got the money together for replacing the motor and getting ready to pull the outdrive once I find out what gaskets I'll need to get everything back together. I'm pretty sure I've IDed the outdrive as pre-alpha with the hump on the top of the outdrive with the hole in it. Are there any other mercruiser outdrives with the hump and hole? What gaskets do I need for the replacement project? From what I've found I think I need Sierra # 18-2614 for the outdrive gasket? [I'm wanting to also replace the impeller while the outdrive is disassembled. What part number should I search for when looking for this part and seals?] Anything else I should do when I'm into this project?
