I have a 70 hp 1973 chrysler model #707hf serial# 20092.After reading through hundreds of posts I discovered that it was a 73,my question is can you have a motor that was built on the edge of a model year my plug wires read 72 the side of the carbs read 72 I don't know if that was just by chance. The reason I ask is I am getting ready to buy parts and want to make sure that I get the right ones...
Motor sat for about 4 years, after a little TLC I got it started,ran good on muffs trottled up great,took it to the lake yesterday unloaded ,started up,went to put in gear and it stalled,adjusted on mixture screw turned each out about 2 turns and it didn,t stall but would just barely go.after reading lots of posts about fuel pump I removed it and the diaphram is not split but it is hard and difficult to move I am going to replace does anyone have anyother things I should check after this,Thanks for any help...
