  #1
Old August 1st, 2007, 11:08 PM
jwilkey84 jwilkey84 is offline
Default mercury kiekhaefer mark58a not cooling properly
I don't thing my 45 horse merc is cooling properly, but I don't know much about how it is supposed to work. The impellor looks fine. Water comes out the pee/exhause hole near the top back of the motor, but it just spits out water, is that all it is supposed to do? It is almost a real heavy drip, it doesn't shoot out or anything like that. Another thing, the water that does come out is kinda hot. I mean, you can touch it, but you wouldn't want to hold your hand there too long. Also you cannot keep your hand on the enging block for more than two seconds because it is hot. I dont think this is normal, but I just want to make sure. Does this old of a motor have a thermostat? Could the water tube be clogged? How do I fix this?
  #2
Old August 2nd, 2007, 12:56 AM
diaric's Avatar
diaric diaric is offline
Default Re: mercury kiekhaefer mark58a not cooling properly
no thermostat. impellor veins should sping out if removed from pump. if they stay bent, rubber is hard and not working properly. tube culd be plugged, or leaking, tube connections could be leaking or water passeges plugged
  #3
Old August 2nd, 2007, 04:34 PM
how do I get to the top end of the water tube and connections? Do I take off the mid section between the lower unit and the top portion of the engine. I know the impellor fans out when taken out, because it did that and I had a heck of a time getting it back in
  #4
Old August 2nd, 2007, 07:02 PM
Laddies Laddies is offline
You may hane the powerherd base gasket leaking letting water cycle down the inside of the mid section instead of cooling the powerhead, if you remove the powerhead to ck be sure the water discharge hole (telltale) on the bottom cowl is open.
  #5
Old August 2nd, 2007, 09:36 PM
There was also some water/oily substance leaking from the seam between the midsection and top section. I found a couple of loose nuts on the outside of the motor that connects the mid and upper section, and I tightened them, but I am not for sure if that stopped it totally. Could that be part of it too. Is ther a gasket there? How hard is it to remove the powerhead?
  #6
Old August 2nd, 2007, 10:04 PM
Yes, thats the gasket I was talking about. Just remove the 8 nuts, shift and throttle linkage and the wiring harness and it will come off. If you don't have a manual at lest goto the BAM Marine site and look at the parts breakdown
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
help with 100 hp mercury kiekhaefer harvick29 Mercury & Mariner Outboards 1 July 23rd, 2007 11:39 AM
8hp Evinrude not cooling properly sue_ring Johnson & Evinrude Outboards 2 July 19th, 2006 01:51 PM
MERC. KIEKHAEFER COOLING PROBLEM Dave Shipos Mercury & Mariner Outboards 1 May 24th, 2005 03:03 PM
Kiekhaefer Mercury 7.5 identification Bearcamp Mercury & Mariner Outboards 0 May 22nd, 2003 01:10 PM
KiekHaefer Mercury jacksonceo65 Mercury & Mariner Outboards 3 June 23rd, 2002 09:19 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
