Re: Gelcoat repair.
I'm not sure why people always recommend Marine Tex for every type of repair, it's good for some things, but not the best for repairing small dings and chips in visible areas. You can get a gel coat repair kit with pigments and instructions so you can at least try to color match the repair. Plus while you can buff the epoxy and get it to shine, it has poor UV resistance, so it won't last long. Epoxy is also much more difficult to sand, so unless your careful, you can get an uneven surface, the gel coat around the epoxy sands down faster than the epoxy and sometimes you will sand through it before the epoxy is to the correct level.
PS. White is not white, Almost every boat builder has their own color of white. You may get lucky and what you buy will come close, but with a few pigments and a little trial and error, you will be able to get it closer.
