  #1
Old August 1st, 2007, 06:16 PM
scottpellegrin scottpellegrin is offline
Default 1993 150hp Evinrude Ignition Trouble.
Over the last few weeks my engine would misfire on occasion when at wide open throttle. Some times just a little blip, other times I would have to go to 3/4 throttle to get it to stop misfiring. Just last night I ran 3 miles across lake wissota with no trouble at all. I stopped and fished for about 45 min then started the engine again and was going to head up just a little farther. As soon as the boat got on plane the engine killed as if I had turned the key off, no spit or sputter at all. I checked for spark when I was on the water and there was none. Tonight when I got home from work I thought I would put the muffs on it and try to start it. Soon as I turned the key it fired and ran perfect. I let it run for about 5 minutes and then shut it off and wrote this message. Where do I begin with this thing, or what do you think the culprit might be? Just a note I worked on helicopters for 5 years so don’t be afraid to put me to work with troubleshooting this thing. Any help would be greatly appreciated.
  #2
Old August 1st, 2007, 06:56 PM
mikesea mikesea is offline
Default Re: 1993 150hp Evinrude Ignition Trouble.
look for obvious wiring probs.but it sounds like your key switch may be going bad,OR if you have a safety lanyard,they do wear out and cause the kill circut to get the ground that kills the eng.If it happens while your out again,disconnect your red harness plug,jump your starter,if the problem goes away,its between the harness and switch usually,be CAREFUL,you will have no way to kill other than disconnecting fuel or manually choking,if you find no spark in the driveway,do the plug disconnect ,check spark,its probably something simple
  #3
Old August 1st, 2007, 08:30 PM
Walker Walker is offline
I though I responded to this post yesterday. Anyway, I'd bet its your powerpack. I've seen several of those V6 Loopers act the same way. Eventually the powerpack will completely fail. Need to test it though. Expensive part to replace because you think its bad.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1993 150hp Evinrude Ignition Trouble. scottpellegrin Johnson & Evinrude Outboards 1 August 1st, 2007 09:33 AM
1993 150hp Evinrude Ignition Trouble. scottpellegrin Johnson & Evinrude Outboards 1 July 31st, 2007 10:09 PM
trouble with evinrude motor 1993 15hp knownascrll Johnson & Evinrude Outboards 4 July 29th, 2007 10:15 PM
1993 Evinrude 150hp V6 fuel economy question Hamish1 Johnson & Evinrude Outboards 2 January 31st, 2005 03:38 PM
1993 Evinrude Carb/ignition sync/timing zspinner Johnson & Evinrude Outboards 1 July 8th, 2003 05:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
