Re: water pump problem
depends how long since its been changed, should be done ever 2nd year minnimum. you could probably get by with just the impeller, but a kit will give you all new gaskets and a wear plate. if its been a long time, may have trouble getting upper cover off pump and may need a new one once you pry it off. once you have it apart, put the water tube up into the power head and hook a hose to it. see if water flows out properly and through pee hole. if not, run weed eater line or compressed air through hole and unplug line. if your old impeller is non existant, if may take some flushing and probing etc to get the pieces out. i just changed the impeller on my old 66 merc, the first time, pee was still weak, a kit gave better flow as pump parts were worn. if you have no water in lower unit oil issues, then leave pump base alone. its not a hard job to do, a helper comes in handy for reassembly
