Re: 1993 150hp Evinrude Ignition Trouble.
First I would eliminate the SLOW system as a problem. Start and warm the motor. Run the motor at 3/4 throttle and feel the heads. If they are not overheating, you may have a bad temperature sensor. Now disconnect the port temperature sensor, and try that WOT run. If the miss disappears, you have found the culprit.(bad temp sensor)
When you lost spark, did you lose it on both sides of the motor? The shift assist module kills spark to one side. You may need to disconnect that and see if that is the culprit.
Other than those two possibilities, make sure your getting enough fuel flow.
