Compatible? Mercruiser 165hp vs 190Hp (3.7l)
gost
Hi all, as my present engine Mercruiser 3.7l 165hp -87 is knocking, I've plans on buying another one. I have found a 3.7l 190hp I guess from -89.
Are they compatible? regarding cooling motormounts and so on?
achris
More fish than mountain goat
Re: Compatible? Mercruiser 165hp vs 190Hp (3.7l)
The short answer is 'yes'. The only difference is that the 190 has a bigger carb and redesigned exhaust, other than that they are identical.
Chris...........
gost
Thanks, so I guess I only have to look for the common problems, leaking waterpump, alternator, an 3 or 4" cooling?
achris
Don't quote me on this, but I think the 190s came standard with the 5" heat exchanger....
Chris................
gost
No other who knows? or have done this swap?
gost
Just wanna bring this to the top.
According to www.mercruiserparts.com they seems to be compatible?, but 190hp seems older than 165hp.
I need help in this so I dont buy an incompatible engine - anyone?
They only built those motors for a Few years,...... They're All pretty much the Same.......
gost
Pretty much the same? Of what I can find the difference are Carburetor and fuel pump.
Anyone who knows the answer to my question - are 165hp and 190hp compatible? meaning can I replace a 165hp with a 190hp engine?
gost
Thanks for the reply, but the the engine I'm planning to buy are a complete engine with careburator and alternator and so on, but I guess that changes nothing?
achris
It will be a straight drop-in replacement.
Chris.........
