  #1
Old July 31st, 2007, 11:11 AM
aquaman8 aquaman8 is offline
Default Evinrude 40 HP (1973) Pinion Gear Problem
Hi All,
Just took a gear case apart on an old 1973 40 HP Noresman (Model 40355)and found that one of the teeth on the pinion gear (driven by the drive shaft) is missing about half the material along its length. There were metal filings and some chunks in the gearcase. Some bearing surfaces are a little scourded, especially the clutch dog.
I know that this can't be good, but I had a couple of questions:
1) Can I run it like this or will it rapidly self-destruct?
2) If it does self-destruct will it cause significant collateral damage inside the gearcase?
3) Can I find a just a used pinion gear and replace the broken one, or do I need to replace the pinion gear and the forward and reverse gears as well?
4) How big a job is replaceing what needs to be replaced?
Thanks for taking the time to help an outboard newbie through the teething process (pardon the bad pun!)
Mitch
  #2
Old July 31st, 2007, 11:25 AM
darrklim2's Avatar
darrklim2 darrklim2 is offline
Send a message via MSN to darrklim2
Default Re: Evinrude 40 HP (1973) Pinion Gear Problem
Quote:
Originally Posted by aquaman8 View Post
Hi All,
Mitch
1. Not recommended, Probably
2. I think so
3. If one is that bad I am sure it wasn't good for the others probably should look at replacing them too.
4. I haven't done this my self, but with the help of a good manual I belive it could be done by most with the will and some mechanical ability.
Of course this is all just my opinion I am sure there is someone else that might think differently. There are many others on this site with much more experience than I. Good Luck
  #3
Old July 31st, 2007, 11:36 AM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
The pinion gear can be purchased seperately if you can find one. It is currently listed as being unavailable. The part number is 317336 and I suspose that someone still has one sitting on their shelf somewhere.
With that gear damaged, take a real good look at the other gears for damaged chipped teeth. If damaged, they will require replacing also.
It would probably be cheaper to locate a good used lower unit BUT check around for the parts first.
1 - Yes, it will self destruct.
2 - Yes, it will tear up everything else in the gearcase.
3 - Answered above.
4 - Fairly easy BUT use a manual to avoid common mistakes.
  #4
Old July 31st, 2007, 07:40 PM
jl_photo jl_photo is offline
If you end up purchasing a used lower unit, i might like to buy the drive shaft if it is a short shaft.
or if you want a longer motor I have a 5 inch extension with matching shift arm and drive shaft to trade.
you might search for that part number on " dogpile.com "
carefully check all of the other components. that gear did not damage itself, it takes 2.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'71 Evinrude 25hp electric start - pinion gear? Steve Wilke Johnson & Evinrude Outboards 0 May 23rd, 2007 02:38 PM
evinrude pinion gear cullracing Johnson & Evinrude Outboards 2 August 15th, 2006 09:59 AM
Pinion gear needed 40 hp Evinrude Merrill Johnson & Evinrude Outboards 1 July 23rd, 2005 06:27 AM
1973 6HP Evinrude Broken Pinion Gear cacioa Johnson & Evinrude Outboards 2 January 7th, 2004 05:03 AM
86 Evinrude 15hp Pinion Gear Spring?? imported_Warren Johnson & Evinrude Outboards 4 November 22nd, 2003 07:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
