studlymandingo
- Mar 22, 2006
- 2,716
So I ran across a deal today. I was in Tampa finishing up some work this morning when I ran across a 1996 Kawasaki 1100 ZXi JetSki on a nice 2003 Performance trailer. I talked with the owner who said it ran great last season, but he was unable to get it started this year. I checked the compression (I was headed to a buddy's house to check his outboard) it was 140 psi on all three (I don't know what this motor is supposed to be but it seemed good) had spark on all 3, and the gas smelled REALLY stale. I talked him down to 900.00 and exchanged money for title. The motor has an "Ocean Pro" head and "Ocean Pro Vortex" carbs on it; the head has a notice stamped in it that says to use 92 octane or above fuel. I assume these are performance mods.
I got the PWC home (this is my first PWC) siphoned out as much of the old fuel as I could, sprayed out the carbs, put in some new fuel and oil and cranked it. It sputtered a bit, then started. At first it was pretty rough and smoky, but gradually began to smooth out. I still haven't quite figured out the adjustment on the carbs, but I think once I find a manual I'll have her purring like a kitten.
I later took her out to the bay and checked it out. I was able to get the speedo to bury the 70 MPH mark; man is that fast when you're that close to the water! It feels like the motor could run a little faster, but I feel like I was close to maxxed out; I'm sure that will change after I get used to it.
I have a few questions about the PWC that I posted in the PWC forum; just wanted to share my find with you guys!
