benjaminok
- Dec 30, 2006
- 28
Hello all.
I have just gotten a new boat, which came with this Evinrude 55HP 1969
# 55973A which is hydro-electric as far as i found out.
However i have some trouble starting it and making it run.
Sometimes the motor starts and will run for approx. 15-20 secs and then dies (at idle speed, have tried shifting to reverse or forward and rev the motor up, but that does not change anything.)
Compression shows:
118
120
120
Spark on all three cylinders, however have only testet with plug against powerhead as i did not have my sparktester handy.
Previous owner told me that gas in tank was new, will try to change to fresh gas, however since the motor runs for 20 sec i guess it should not be "old" gas? Will also try to change plugs, however i think the problem is something else.
The motor dies quite slowly, like starving and not getting fuel, but plugs are wet. Also i noticed that slow speed needles were set at 1/4 turn, however i see that they should be adjusted to 1 1/2 initial setting.
Any other thoughts on how to troubleshoot this vintage?
Your inputs are as always very much appretiated!
Well just saw that initial setting for slow speed needle is supposed to be 5/8 turn acc. to manual.
Compression shows:
118
120
120
