hckrphil
- Aug 8, 2004
- 162
I'm looking at buying a 1994 Real Rush jet boat. It has a Mercury Black Max 90HP 3 cylinder engine. Boat is in great shape, but engine has a problem.
One out of the 3 cylinders is showing a very low compression reading of about 30lbs I believe.
Any ideas the cost to repair this? What should I look at? The boat WAS running fine, booked along nicely at 50MPH. Then something happened???
If I can get the boat for $1000, think its worth it? Cost to repair engine?
Its got the mercury engine, with a jet lower unit. I wonder if I could swap out the 90HP Mercury with a 110HP engine?
Thanks for all your help!
Phil
Phil
