  #1
Old July 30th, 2007, 07:46 PM
scottrbishop scottrbishop is offline
Default 1973 Mercury 850 85HP correct Tachometer?
The tach in that came with my boat isn't giving me the right readings and I want to make sure I replace it with the right thing.
http://cgi.ebay.com/ebaymotors/ws/eB...104592828&rd=1
will this Quicksilver tach work on my motor? It looks the same but my manual doesn't give me a model # for the replacement. Will a 65794A2/73370A2 work, or should I look for a different aftermarket tach? Thanks!
  #2
Old July 30th, 2007, 09:42 PM
Default Re: 1973 Mercury 850 85HP correct Tachometer?
I should probably also mention that this is a Thunderbolt Ignition model. I've read several threads on here about people having a hard time getting the correct tachometer for a thunderbolt ignition. Is there something special I have to look for?
  #3
Old July 31st, 2007, 05:39 AM
ricksrster's Avatar
ricksrster ricksrster is offline
I just tried to look up the part number on mercury parts express.com. It is no longer available. For the price of the tach on ebay , you can get a Teleflex or Faria here at iboats.com. They come with complete instructions on how to install.
__________________
"Many of the greatest sailors were pukers."--Thorfinn Skullsplitter
  #4
Old July 31st, 2007, 10:16 AM
linckeil linckeil is offline
I don't know about the part numbers, but my 1973 sea ray with original 1973 merc 850 has a tach in it that looks identical to that one.
  #5
Old July 31st, 2007, 01:21 PM
Chris1956 Chris1956 is offline
Cool Re: 1973 Mercury 850 85HP correct Tachometer?
Scott, That motor will work with all the aftermarket universal tachometers. In 1973, merc made unique tachs that ran off the switchbox pulses. They wired their motors to use these unique tachs. The one on e-Bay may be that type, but I do not know for sure. However, you may easily convert your motor to run off the aftermarket tach instead.
When the older mercs came from the factory the brown wire (tach signal) was connected to the switchbox on the motor. If you move the brown wire to either of the AC connections of the rectifier, the aftermarket tach will work. Set it to 6P.
  #6
Old July 31st, 2007, 02:58 PM
pman7 pman7 is offline
Chris, are you saying he should just disconnect the brown wire from the switchbox and move it over to either AC side of the rectifier? So in other words that brown wire has no other function than carrying motor impulses from the switchbox to the tach?
  #7
Old July 31st, 2007, 04:29 PM
ricksrster's Avatar
That is correct.
__________________
  #8
Old July 31st, 2007, 05:24 PM
Thanks for the responses guys, I decided to go for the aftermarket tach. I see the brown wire on the switchbox and I see both of the yellow/red wires on the rectifier, but the brown cable coming from the distributor isn't long enough to make it to the rectifier on the other side of the engine. What should I do?
  #9
Old July 31st, 2007, 05:30 PM
its not the brown wire from the distributor you want to move. its the brown wire on the other side of the switchbox you need to move.
take a look at this picture for help.
http://www.maxrules.com/oldmercs/Wiring/1966ona/30.pdf
  #10
Old July 31st, 2007, 05:36 PM
Ahh, so the brown wire that runs from the engine harness? Disconnect from the switchbox and run to the rect? I'll run outside and check out the motor and report back.
  #11
Old July 31st, 2007, 06:36 PM
Got her all hooked up and I'm on my way to the lake to try it out in half an hour. Just to verify, the AC side of the rect is the yellow/red wire(s), not the solid red wire, correct?
  #12
Old July 31st, 2007, 08:17 PM
yes, the 2 yellow/red wires run to the stator. you want to double up the brown wire on either one of the contacts where the yellow/red wires hook up to the rectifier.
  #13
Old July 31st, 2007, 10:53 PM
Took it out on the lake today and it was a no go.. I think my problem is that I don't have a wire running to the IGN post on the tach. My old quicksilver tach the black wire running to NEG, the brown running to POS and another wire briging POS to the mounting bracket, and a white wire running to the light. What wire should I be running to IGN? It says 12-16 volts, can this be any 12 volt wire (take a tap off my CD player?) or does it need to run to the control box so the tach knows when to turn off and not drain my battery? I'd really appreciate a shove in the right direction, you guys have been awesome so far.
  #14
Old August 1st, 2007, 04:03 AM
ricksrster's Avatar
IGN on the tach is 12V+ from the key switch. When you turn the key on. The white wire on the ignition switch.
__________________
  #15
Old August 1st, 2007, 05:29 AM
So would that be the white wire on the control box that is labeled "tach Connector" on this diagram?
  #16
Old August 1st, 2007, 07:22 AM
ricksrster's Avatar
Yes. That is the one.
__________________
  #17
Old August 2nd, 2007, 06:18 PM
I tracked down the white wire and apparently it ran to the backlight of my old quicksilver tach. I'm leaving for radio shack to buy another ring terminal so I can chop the wire and reattach to the tach. I'll post back with results.
  #18
Old August 2nd, 2007, 10:16 PM
She's alive!! One problem though, it's not reading the correct RPMs. At WOT It's only reading about 3600 when I know I'm going about 5200. The Teleflex Manual says to set the thing to 4P and everyone else tells me 6P. How can I tell how many poles are on my alternator?
  #19
Old August 3rd, 2007, 12:47 AM
ricksrster's Avatar
6P is the correct setting. You have a 12 pole alternator which is 6 pulse. 6P should correct the issue.
__________________
  #20
Old August 3rd, 2007, 02:55 PM
Looks like the back of the tach was already set at 6P. The voltage regulator is also brand new installed at the dealer and the battery is getting a good charge. What else could it be? Could the previous owner have installed a different size alternator?
  #21
Old August 3rd, 2007, 04:14 PM
Quote:
How do you "know" it's going 5200?
  #22
Old August 3rd, 2007, 05:04 PM
I just had the boat out on the river with my marine mechanic about a week ago and he hooked up his marine tach and it read 5200. The boat hasn't changed performance wise, and it rips on to plane in a couple seconds. I don't see any way the motor could turn an extra 1600 RPM.
  #23
The response I got from Teleflex was to try setting it to 5p or 4p and see if I could match the tach to actual RPMs. Is there a logical reason why another setting would be accurate?
  #24
Old August 3rd, 2007, 05:24 PM
Question Re: 1973 Mercury 850 85HP correct Tachometer?
Scott, Unless your Stator is bad or an incorrect model(and I do not even know if that is possible), 6P should be the setting. Sounds like the techs were grasping at straws.....
  #25
Old August 5th, 2007, 11:45 PM
Hmmm... The dealer said the Stator was checked and found to be good, wouldn't a bad stator also give me some engine trouble? Is there really nothing else that this could be? Should I resort to exchanging the tach for another at the store?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 Mercury 850 85HP WOT RPM? scottrbishop Mercury & Mariner Outboards 1 July 30th, 2007 07:31 PM
Correct Tachometer for 1972 Thunderbolt ignition donwhiteside Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 February 27th, 2007 04:34 PM
Mercury 850 Thunderbolt (85hp) What is the correct Lower Unit for this model? fomoco-gnatsum Mercury & Mariner Outboards 3 August 22nd, 2003 07:16 PM
1973 85HP Mercury Motor Mounting Bracket shimmerboo Mercury & Mariner Outboards 0 June 28th, 2002 10:46 AM
1973 85HP Mercury SteveandCarrie Mercury & Mariner Outboards 2 May 13th, 2002 07:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
