  #1
Old July 30th, 2007, 04:46 PM
jaymasta jaymasta is offline
Default 1996 mariner 20hp impeller question
hey guys I have started the job, put the gear shift in forward I removed the trim tab, removed the 4 bolts that hold the lower unit on and iam at the point where Iam trying to get the L/U off it comes down about an inch and a half and it appears to be getting hung up on the shift shaft, I have tried it in forward, neutral and reverse and its all the same thing I don't want to force anything, any tips as to why it isn't coming off for me or have I missed a step?
thanks
Jason
  #2
Old July 30th, 2007, 05:43 PM
Texasmark's Avatar
Texasmark Texasmark is offline
Default Re: 1996 mariner 20hp impeller question
I'm a bigger engine guy, but in reading others threads, who talk about your size engine, you may have an upper clamp holding it on.
I'd start with the shifter (the actual lever you touch to shift) and follow the mechanics back into the engine. You have an idea where the shift rod comes up by observing where the shaft is....just a matter of following it up.
Bigger Mercs twist to shift. Maybe yours does too. So, I'd look for an interface between the vertical shift rod and the shifter lever. You will probably find a lever arm clamped onto the shift shaft,operated by the shifter lever and jammed up against something below it.
Unscrewing it and prising it off will probably solve your problem.
HTH
Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 mariner 60- water pump question bitzer26 Mercury & Mariner Outboards 4 May 28th, 2008 08:46 PM
'03 20HP Merc impeller - started job, need advice lakelover Mercury & Mariner Outboards 1 June 2nd, 2007 07:04 PM
1996 Mercury 20HP -- Reverse Only! iehmove Mercury & Mariner Outboards 0 June 15th, 2004 11:06 AM
Impeller P/N and a impeller/housing rebuild kit P/N for Mercury 200 20HP S/N 508 rklies Mercury & Mariner Outboards 3 June 13th, 2003 12:56 PM
Impeller P/N and a impeller/housing rebuild kit P/N for Mercury 200 20HP S/N 508 rklies Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 13th, 2003 12:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
