Re: Trolling motor for Sea Ray bowrider
you can have a alluminum pod made. or depending on your swimgrid you could mount one there. inboard ,make a pod, outboard, mount a bracket. if your boat is 2500 lbs or less you can use a 8 hp if more use a 9.9. you can jion into your exsisting fuel line. measure from your mount for the kicker to your lower hull to find out want leg length you need.
