Re: zodiac repair
You can use a heat gun but I will not recommend it as you can burn the boat if you don't know what you are doing ..... as far as I know it is cold and wet conditions that doesn't work well with the glue, but anyway, if you are concerned about the humidity, then put on a gas heater or something in the room you are repairing the boat so it dries out the air ..... I would not use stabond either ....... it is a good idea to sand the patch and the area where you are going to patch .....
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
