Have Fun Today
- Jun 29, 2007
- 58
I've been reading alot about water and cooling problems. Most problems seem to be related to or the cause of a lack of water flow from the outdrive to the circulating pump. The temperature gage is unreliable without any water in the cooling system. A water sensor, along with the temperature gage, would be a good indication of cooling water available to avoid causing any damage.
Is there any type of a sensor I can install to see if water is flowing to the circulating pump on the engine? I'm thinking of something that I could insert into the inlet hose to the circulating pump with a light connected and installed on the dash to alert me of no water. Better yet, a flow rate meter. Or the simplest solution, a clear water hose I can examing while the engine is running. Anything like this available on the boating or automotive market?
