clamp rings
bradyandjen
My wife and I, are looking for some clamp rings for our volvo penta outboard.
One for the outbourd itself, and the one on the back boat. The boat is a Bayliner Cuddy Cabin. It is a 1982 model, that is 21ft long with a 8ft beam.
If anyone can help it would be great Brady and Jennifer Oberman Paris, Arkansas.
njlarry
Re: clamp rings
Welcome! Someone here may have the answer but they will need to know year and model engine. Serial number will also help confirm both. If you have the old clamps you can just take them to a marine store.
Don S
Re: clamp rings
What are you calling "Clamp Rings". There is a part on the OUTDRIVE (It's not called an Outboard) upper gear box that has the input shaft and bearings in it and the bellows clamps onto it, that is called a clamp ring, but unless you have a way to set rolling torque on the input shaft and shim for backlash, then you should have a shop replace it.
