Re: Johnson water pump impeller
The 9.5 is a fairly easy one to change. Four bolts and disconnect the coupler by removing the screw will get you to the pump. If everything is in reasonably good shape, you should be looking at about 1/2 hour. When you remove the 4 bolts facing upward, open the unit enough to find the shift rod coupler.
