  #1
Old July 28th, 2007, 11:13 AM
jimg984 jimg984 is offline
Default Grear Ratio 1978 1150 Mercury 115 Hp
need to know the gear ratio for this motor
going to put it on a 16 foot fiberglass trihull boat which is a 1965 pipestone boat its a heavy boat the prop on the 115 is a 17 inch pitch, what can i expect for top speed with this comb.? also have motor running, never had the boat out to the lake. idles too fast prob. 1500 ---2000 rpm cant find the idle down adjuster. Selco manual says screw on top bracket top bracket works from the distrubtor is the adj one of the screws on dist
ths jimg984
TOWER OF POWER SOUNDS LIKE AN DRAGESTER LOL
  #2
Old July 28th, 2007, 11:20 AM
Laddies Laddies is offline
Default Re: Grear Ratio 1978 1150 Mercury 115 Hp
14/28 -- 2 to 1
  #3
Old July 28th, 2007, 12:52 PM
ths for the info how about the idle adjuster?
  #4
Old July 28th, 2007, 01:19 PM
I use a basic setting of 2 turns on inline 6s, some people use 1 1/2 turns, whatever it will idle at, the thing that has to be done is the engine adjusted in the water, in gear set the idle speed at 700 to 750 and start on the top card screw the mixture screw in till the engine drops RPM then richen it till it smooths out + 1/4 turn work your way down. I run the adjustments top to bottom 1 time for each carb to get the best adjustment, in the case of a 115 that would be 3 times then re adjust the idle to around 750 in gear
  #5
Old July 28th, 2007, 02:19 PM
i dont think the problem is with the mixture,,, and thanks for the information on adjusting the mixture
seems like the top lever is hitting the lever from the distrubtor which is hitting the metal framing and not letting the throttle plates close
can the throttle lever stop on each carb. be adjusted on the throttle shaft?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
gear ratio for 76 1150 Plainsman Prop Questions and Topics 5 August 13th, 2006 01:50 PM
1978 1150 pfoley Mercury & Mariner Outboards 23 April 26th, 2006 11:25 AM
1978 Mercury 800,direct 4 charge, 80 hp fuel mixture ratio JJCOWGIRL Non-Repair Outboard Discussions 1 June 14th, 2005 02:49 PM
Mercury 4HP 1978 Belgian, Fuel Ratio? bassmandan89 Mercury & Mariner Outboards 3 October 20th, 2004 09:37 PM
Oil for 1978 Mercury 1150?? johnson1 Mercury & Mariner Outboards 3 May 9th, 2003 09:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
