New problem with a used boat/motor. Imagine that.
Friend recently acquired this project. Prior owners said it had been sitting for about five years. Hull is an 87(?) Bass Tracker, engine is a Mariner 45 HP inline four of the same vintage.
When he bought it, the motor was tilted full up, and a transom saver was installed. When he got it home, he lifted up on the L/U, removed the transom saver and the motor went down as if by gravity (not bleeding down).
We worked on it yesterday and today, and the tilt/trim is inop. The switch had broken-off posts (wiring connectors); we replaced the switch and terminals and gave it a try. Click Click. Okay, solenoids are energizing. Checked voltage at the large (power) wires and 12v is available at each.
Connections are tight (some were not before). It is clear that somebody has been messing with this stuff, but not for "quite a while".
Due to the fact that we cannot get it to tilt up (I'm betting it is hydraulic-locked in position) , I cannot check anything at the motor itself, but the downstream side of the solenoid (blue and green large diameter wires respectively) are powered when the switch is in the appropriate position.
How can I get the motor "up" (not necessarily electrically)?
What is the function of the small plastic thumbscrew-type device on the right side of the transom clamp? It is spinning loose, and not attached to anything. Almost wants to fall out, but is "flanged" (flange larger in diameter than the hole it pokes through). I'm thinking there has to be some sort of pressure relief valve somewhere...
