  #1
Old July 26th, 2007, 01:02 PM
ernaldamerican ernaldamerican is offline
Default Oil pressure for mercury (GM 350) 260 hp alpha 1 drive
I have a 1985 chris craft and am assuming the motor is of the late 80's early 90's vintage. I have put an oil pressure gauge tee'd into the oil pressure sending unit line (up stream0. At idle I am getting around 60 psi for oil pressure.
What is the acceptable or normal range for oil pressure at idels for 350 motor?
  #2
Old July 26th, 2007, 01:11 PM
Haut Medoc's Avatar
Haut Medoc Haut Medoc is offline
Default Re: Oil pressure for mercury (GM 350) 260 hp alpha 1 drive
Welcome to iboats.....
I would think it would be lower......
The min. psi is about 5......
The max should be 70 or so......
What is the PSI @ 2,000 RPM?........
__________________
Disclaimer!: In my inexpert opinion......
  #3
Old July 26th, 2007, 02:16 PM
Silvertip Silvertip is offline
60 PSI is not overly high on a "cold" engine. At idle, after fully warmed up it will typically be in 35 - 40 PSI range. After a hard run at WOT it may drop to 20 when returned to idle but it will gradually rise again after the engine has cooled a bit.
  #4
Old July 26th, 2007, 02:53 PM
Thanks for the replies. I need to state that the gauge on the console will read 40 ish at idle (cold) but the gauge at the T I have back at the sending unit is reading 60 ish. I think it might be the a problem with gage at the T. i am going to take some numbers tonight (from both gages) at 1000 rpm intervals up to WOT, and then back at idel and reply back with those to see if any one thinks they are out of the normal range.
Again appreciate the advice.
  #5
Old July 26th, 2007, 02:55 PM
tommays's Avatar
tommays tommays is offline
what weight oil your useing and how warm it is will also have an affect on pressure
Tommays
  #6
Old July 27th, 2007, 09:17 AM
All
I am using quicksilver 10w 40 motor oil. Took the boat out last night and have the follwoing data:
Initial start up on lake
RPM oil pressure
1200 (throttle in neutral) 45 psi
700 (throttle in fwd gear) 42 psi
1500 42 psi
2000 42 psi
2500 62 psi
3000 62 psi
3500 62 psi
4200 58 psi
WTO 4200 - 4300 rpm water temp 160 deg f, oil press. 58 psi
came back from WTO to 2500 rpm and oil pressure was 42 psi
came back to idle (throttle in fwd) and Oil pressure was 22 psi
  #7
Old July 27th, 2007, 09:49 AM
tommays's Avatar
I believe the quicksilver 10-40 is a 4 stroke outboard oil as merc recmonds there 25-40 or ST-30 ,ST-40 or ST-50 depending on temp where you boat
Tommays
  #8
Old July 27th, 2007, 10:28 AM
My apolgies, I need to double check the oil viscosity. I got it from boat dealer for inbaord 4 stroke but could have grapped the wrong one. i will check.
  #9
Old July 30th, 2007, 09:47 PM
Sorry for getting back so late. you were absolutely correct its 25w-40.
Do the pressures look correct for this weight of oil?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
will a 2004 alpha drive fit 1998 alpha dnbeachboy Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 7th, 2007 09:19 PM
how to tell what drive ratio my alpha drive is? lime4x4 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 June 26th, 2007 09:55 PM
Alpha 1 upper drive fails pressure test Haut Medoc Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 3rd, 2005 10:39 PM
Mercury alpha-one drive .shift re-assembly? Benzie Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 December 19th, 2004 03:20 AM
Mercury alpha-one drive .shift re-assembly? Benzie Mercury & Mariner Outboards 3 December 14th, 2004 02:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
