Re: WOT Question
The fact that it doesn't cavitate in a turn simply says that the engine is not set too high but that doesn't mean it couldn't be set higher. About your prop I'm not sure what the 13 means on that one. Maybe you could find it on the manf. web site. One way or the other you should try to find out what is so at least you know your starting point in case you want to try a different prop. If you move to a lower pitch prop you will increase RPM's, you will gain advantage in the hole shot but you'll give up some speed. On the otherhand, if you are able to raise your engine and get the additional 300 rpm you will improve speed and possible hole shot as well.
