Re: Spark plug wires ?
I think "marine" plug wires are a load of crap.
Ayuh,............ To a point,..... You're Right..........
But,............
All sparkplug Wires are
Application Specific,................
Some Dist. Caps have Innies,+ Some have Outies,...... Just like your belly button.......
Also,.......
Some wire sets have Straight Plug Boots,+ others have Angled Boots,.........
Some have longer wires(or Shorter) for different Routing of the wires........
A couple yeas ago,...... I needed a set for My 4.3LX,..... I also had a Brand New set for a 4.3l pickup truck.......
Soooo,..... I Tried to use them,..... It didn't Work,..... They were mostly Too Short,.... The pickup truck ran the wires up,+ over the motor,.... Merc. runs them Down,+ Under the Exhaust..... That,+ the Straight plug boots, made most of them Too Short........
So,..........
You're Right in that there's No Difference in the
Actual Wire used,.......
But,.......There will be a Difference in the final finished Product,......
Which May, or may Not fit your motor.........
