  #1
Old July 25th, 2007, 08:20 PM
HondaPower HondaPower is offline
Default Carb Idle Mixture Setting 85 Mariner 50
Finally finished rebuilding my Lowe 16 foot Bass Boat and took it out on Sunday. The motor ran well but after some hours of fishing using the trolling motor it was a different story on the way to the launch. Motor started well but would die when given throttle. After a number of attempts I used the contol button to rev the motor in neutral, no problems. Ran it at 2000 RPM for a few seconds and then put it in gear and away we went with good throttle response. Read my manual to see how to set the idle mixture as it seems to be starving for gas upon acceleration. It tellls me to turn in until the engine slows and misfires, and then to turn it out 1 to 1 1/2 turns. I checked the carb settings and they are both at 1 1/4 turns from seated. I am guessing they are set to lean and causing my problems. The gas lines are good, the carbs were rebuilt when I bought it late last year and the plugs are new. I will try adjusting the idle mixture tomorrow but wondering if I am on the right track.
  #2
Old July 25th, 2007, 09:55 PM
Laddies Laddies is offline
Default Re: Carb Idle Mixture Setting 85 Mariner 50
If you have to clean it out by reving it up before shifting it's probably to rich. When adjusting idle mix on those carbs, adjust them in gear, screw the needle in 1/8 turn at a time giving the mix a chance to normalize each time when it misfires back it out till the misfire stops and open not more than 1/4 turn, do the other carb and then adjust them again. If after the second adjustment the engine hesitates on acceleration, open both low speeds up 1/8 turn at a time till the flat spot is gone
  #3
Old July 25th, 2007, 10:34 PM
Thanks for the response. Will adjust tomorrow using the information you provided.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What's correct idle mixture screw setting. milkyway Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 June 19th, 2006 10:19 AM
1983 35 Rude idle mixture setting? roscoe Johnson & Evinrude Outboards 2 May 16th, 2005 09:12 AM
Idle Mixture Setting Question U68423 Force & Chrysler Outboards 2 July 24th, 2003 02:41 PM
Idle mixture setting Evinrude 70 bokarlsten Johnson & Evinrude Outboards 3 June 16th, 2002 09:24 AM
1990 Yamaha 130 Idle Mixture Setting? rmrakt Yamaha & Suzuki Outboards 3 May 23rd, 2002 03:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
