thomgallagher
- Jul 2, 2007
- 1
I have a 2000 5.7 Merc w/B3 outdrive in a 2001 Bayliner 2655. Starting last year I noticed little to no activity on my temp gauge. It stayed at, or near bottom.
This year, replaced sending unit (even though it checked out) raw water pump (impeller was only slightly damaged), new 140 degree Tstat, new Temp gauge (not the problem, but wanted new dash gauges). I grounded the temp gauge wires at the sending unit, and it registers as expected, so it's not a wiring problem to the bridge.
I flushed entire system from outdrive to pump, from pump to thermostat housing, from housing through risers and back out the exhaust system. Ran with the muffs, water spews from outdrive as always. All cooling systems check out however, when running it reaches 140 and you can place hand on t'stat housing feel it get warm, then cools again within 30 seconds. Temp gauge shows almost no activity and sits at, or near bottom. Stays this way for 5 minutes, and then repeats. It seems my engine is running way too cool. Risers are warm somewhat evenly.
This is a real head-scratcher..
Eternal thanks will go to the one knowing this secret.
