2004 Johnson 150 overheat
Gary Johnson
Coming out of winter storage, I took the boat out for first time and the motor ran fine for 15 minutes then went into slow mode, alarm and light came on for overheat. I changed the thermostats and impellor kit and still have the same problem. The water is circulating good and doesn't feel hot. If I disconnect the overheat sensors it runs perfectly. Any ideas?
