Re: Evinrude remote throttle control rebuild
the control box (assuming it is an original OMC one) is a piece of cake to fix, and I think all parts are still available, let me guess, you cannot get enough movement to get forward and reverse? you can get neutral and forward OR neutral and reverse but not both! if that is the case, it is the two little gears that move the cable when the lever id shifted (before the throttle picks up)
