  #1
Old July 24th, 2007, 09:30 PM
Egan Dolph Egan Dolph is offline
Question 1991 Bayliner Capri 1700 LS Steering Troubles
I had a huge misfortune a couple weeks ago where my boat trailer came off the hitch while I was getting on the freeway. Luckily I had the safety towing chains attached and I was able to pull over and correct the problem without any serious side effects. The problem is that I think from that incident the engine slammed from port to starboard a couple times and jammed the steering piston. Ive been trying to unjam the piston but Im afraid it is time for a new one. This is where my troubles lay. I cant find a single tech manual that has an explanation of how to remove this steering cylinder. PLease, is there anyone that has had a similar problem and may have a solution?
  #2
Old July 31st, 2007, 12:13 AM
banjoport banjoport is offline
Default Re: 1991 Bayliner Capri 1700 LS Steering Troubles
This is high risk potential for ignorance. I am not familiar with the Capri 17 however I have a Capri 2070 and it doesn't have hydraulic steering. I have an L Drive so if you have an outboard it may be has this steering. At any rate I doubt that this is the source of your problem unless the jolt damaged the ram. Disconnect the steering from the motor and see if the wheel turns freely, if not the problem is in the Hydraulic/cable system. You didn't indicate outboard or L Drive so the simplest check is the one I have proposed. The next check is of the drive unit itself and solution of these problems are expensive. Best get a manual and then go to a parts supplier (ie Crowley Marine or Stem to Stern) and look at the blowup of the prospective damaged part to get an idea of what you are dealing with. Hope this is of some help.
  #3
Old August 2nd, 2007, 12:45 AM
QuadManiac's Avatar
QuadManiac QuadManiac is offline
You should have Teleflex rack and pinion cable steering with the cable output passing througn the engine's tilt tube (this kind of looks like a piston). If you have hydraulic, it's custom. Take a closer look, and if it is the cable type, I'll be glad to try to walk you through removal. I just did it a month ago.
Good Luck!
__________________
'91 Bayliner Capri 1800, Force 90
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Bayliner Capri 1700 CR Tech Specs Greywolf58 Boat Topics and Questions (not engine topics) 5 June 22nd, 2009 04:16 PM
1991 Bayliner Capri 2050cx Prop ?????? WAVENBYE2 Prop Questions and Topics 7 April 12th, 2008 09:09 AM
1996 bayliner capri 1700 LS need help with floor!!! cgaviator Boat Restoration and Building 5 April 30th, 2007 12:26 PM
bayliner capri 1700 90hp prop slipping PERIKO Force & Chrysler Outboards 2 March 8th, 2007 07:13 PM
1989 bayliner 1700 capri with o/b 85 hp, it died when i shift and slow. buddyle Force & Chrysler Outboards 28 June 19th, 2006 10:29 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
