Ok, i have an aerator that was installed last year and ever since it was installed, I have had to "prime" it before use. What I mean is this-once in the water, the first time I turn it on I have to open the back lid, reach down to the aerator, twist the top cap (filter) to let water run through it and then put the cap back on. After that it will work all day on a timer. It's not hooked up backwards and there are no leaks. Any ideas?
Problem #2: The last time I had my boat in for repairs, they forgot to readjust the throttle linkage on the motor. The top adjuster was all the way loose (found out the hard way-on the water). After about an hour of cursing and thinking I had lost a cylinder cause it wouldn't come out of the hole, I saw this and adjusted it on the water. Two problems came with this: one-I have no idea what the proper adjustment is so I just cranked down until I could get it up to 5000rpms. Is this ok or is there another method I could use. #2-the shifter won't go all the way back on reverse-just about in inch and then when I put it back into neutral-I have to wiggle it to get in to go into neutral. Any help here?
Thanks,
Sid
Thanks,
Sid
