  #1
Old July 23rd, 2007, 07:03 PM
julesstar julesstar is offline
Unhappy Mercury XR4 Lower unit Problem HELP!!!
Thank You ALL for your help! What a great site this is. I did find a wire that had a spot where it was won down and was making contact. I fixed the problem and as I was testing it on the water...I was doing about 30MPH when my engine reved high for a second, I shut her down and NOW...It won't go into gear forward or reverse??? I hate to bother you guys but My father-inlaw has a 1989 Mercury 115HP VRO that the lower unit is good. He said I am welcome to it if it will work the power head?? is Bad on it but he said he had the lower unit rebuilt about a year ago...Does anybody know if I could be soooo lucky that this lower unit could fit on my 1989 150XR4 Black Max?? Please HELP!!! This is my 1st boat and my wife already wants to ring my neck!!! LOL Thank you in advance for any help you can give me.
  #2
Old July 23rd, 2007, 07:24 PM
jimc_LA jimc_LA is offline
Default Re: Mercury XR4 Lower unit Problem HELP!!!
From what you describe, it sounds like you may have just spun the hub on your prop. I would check that first before deciding that the lower unit went out.
I would think that if the lower unit went out, there would have been some sort of a clunk or gear noise. Prop hubs sometimes go out under load simply because they're old. Had one do that to me.
Hope that it is just the hub. That's a much cheaper fix.
  #3
Old July 23rd, 2007, 07:37 PM
shep70057 shep70057 is offline
You could start it in the drive way on muffs and see if it actually goes into gear or not.... I don't know that I would try to keep the prop from spinning though. At least you will know if the propshaft is turning or not.
  #4
Old July 23rd, 2007, 07:51 PM
What shep says would be a good test. If the prop turns when you put into gear out of the water (no load) it would be an indication that the hub is spun. Sometimes when you spin the hub, it tears apart so bad that it gives the impression of not going into gear at all.
  #5
Old July 23rd, 2007, 10:28 PM
thinksun thinksun is offline
Check prop as stated and hope for best.
I believe the lower unit is the same and will fit but the gear ratio is very different. Although the props are interchangable you may need a big increase in pitch. The 115 may be 1.87 or 2.0 ratio and the XR4 is 1.78.
I had the prop shaft shear on my 1988 XR4 which was a common problem due to a manufacturing defect (laser 2 prop went down 200 feet never to be found). I later grenaded a bearing and rebuilt gearcase for $2000 to just have it blow again. I found a used 5" case (XR4 and 115 has smaller 4" case) with factory nose cone and low water pick for $1200 and never had a problem after that.
I know the wife thing and "toy boy" as she called me filed for divorce. Being a slow learner I remarried -but to one that appreciates the cost of fun and toys.
Good Luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Finding match between 25 Mercury upper unit and its lower unit Safari89 Mercury & Mariner Outboards 2 July 10th, 2006 11:21 PM
1996 200 HP Mercury Lower Unit or linkage Adj. Problem jorwalke Mercury & Mariner Outboards 1 January 20th, 2005 07:16 AM
67 Mercury 9.8hp lower unit problem gmarshall43 Mercury & Mariner Outboards 5 October 26th, 2004 01:07 PM
Mercury '99 90hp lower unit problem johnswift420 Mercury & Mariner Outboards 0 June 24th, 2002 05:55 PM
Mercury Lower Unit Problem kris_merc Mercury & Mariner Outboards 2 April 10th, 2002 10:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
