siu_basser
- Jun 28, 2007
- 6
I was needing some help on adjusting my forward and reverse cables on my 89 60hp johnson. When putting the motor into forward it goes in really easy and fast. When i put it back into neutral the prop keeps spinning in forward. I adjusted the reverse cable and the grinding noise is pretty close to gone but still will not go all the way in reverse. When the boat is out of the water the motor will go into reverse just fine but not in the water. Could this be bad cables? Or should i order new cables and start from scratch?
