  #1
Old July 22nd, 2007, 11:05 PM
GlasV162 GlasV162 is offline
Default 90 hp Evinrude losing power @ wot
Hi all,
I have a 1990 Evinrude 90 hp; newly-rebuilt powerhead and carburetors. Starts and runs fine, and idles well (about 900 rpm) and runs fine up to about 3500 rpm; after that it loses all power and will only run up to about 4500 rpm; then when slowing down, it won't idle back down; idle is stuck at about 1100 rpm. I'm afraid to shift back into gear at this high an rpm as I don't want to damage anything in the lower unit. I'm bringing the boat back to the shop tomorrow; this will be the 3rd time back to the shop since the rebuild and they still can't seem to diagnose the problem. Any suggestions?
  #2
Old July 22nd, 2007, 11:18 PM
curtisimo1981 curtisimo1981 is offline
Default Re: 90 hp Evinrude losing power @ wot
i had the similar problem on my 89 90hp johnson (basically same motor) it ended up being the throttle cable, for it not idling down. as far as loosing power is your primer bulb tight?
  #3
Old July 22nd, 2007, 11:22 PM
What do you mean by a tight primer bulb? I assume this is something my mechanic would've checked.........but then again maybe not.
  #4
Old July 22nd, 2007, 11:54 PM
Dennisanoka Dennisanoka is offline
May I ask the size of the prop that you are running?
  #5
Old July 23rd, 2007, 12:15 AM
My next question will be what is the height of your engine on the transom/ what is the position of the cavitation plate in respect to the center line of the hull? Higher or lower and by how much? If it's too low and with the wrong prop 4500 is completely understandable. There may not be a single thing wrong with your engine except for the idle down issue which is a much smaller issue to address.
BTW I suggest doing all that you can to keep the mechanic your friend through this process he is still your best source to resolve this.
  #6
Old July 23rd, 2007, 11:55 AM
I'm running a 13 1/4 X 17 pitch prop; cavitation plate is about an inch higher than the bottom of the boat, which I've been told is fine. When running great, I can get 5500-5600 rpm no problem. The last time it was in the shop my mechanic said it was a roller that had developed a flat spot; that was replaced, and it ran great for about 2 hours; then back to the same old thing of losing power at wot. Anyone know about this roller? Thanks.
  #7
Old July 23rd, 2007, 01:08 PM
I would just ask him which one it was, otherwise it's just a guessing game.
  #8
Old July 23rd, 2007, 01:34 PM
Does a faulty roller sound like a reasonable cause of this problem? I mean no disrespect to my mechanic, but this is the 3rd time back to the shop with the same problem--my boat has been in the shop more than in the water this year, so needless to say I'm becoming a bit skeptical. Thanks.
  #9
Old July 26th, 2007, 09:34 PM
Hello,
Well, I'm on trip # 4 to the mechanic. I called him today and he said it was a couple of fouled plugs. He offered to go to the lake with me and I accepted; we set a time for Friday; I told him I would pick the boat up today and try it and get back to him. Still runs poorly. I dropped the boat back at the shop tonight, called him and told him I would stop by at our agreed-upon time for a lake test. Now he says "Call first; I'm kinda booked up tomorrow." I'm trying to keep my cool here but this has gone too far. Any suggestions??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 Evinrude Sportwin 9.5 HP losing power gruntr2000 Johnson & Evinrude Outboards 8 June 29th, 2006 09:52 PM
15HP evinrude losing power at full throttle johnyeh Johnson & Evinrude Outboards 10 January 19th, 2006 09:03 AM
'79 Evinrude 55 HP losing power-Throttle casey7743 Johnson & Evinrude Outboards 2 June 10th, 2004 01:48 PM
1995 48hp evinrude Losing power? Baitbucket Johnson & Evinrude Outboards 1 July 12th, 2002 01:56 PM
Evinrude smoking, losing power @ higher RPM's cvlngineer Johnson & Evinrude Outboards 23 January 28th, 2002 05:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
