Re: Mercury 75 Tilt/Trim Bleeds Down:
Well, I pulled the manual release valve out and it appears that at the inside end of it, it has broken off. The last O ring at the tip was sort of out of position which got my attention. It appears that this plastic valve has broken off, most likely at it's weakest point.. I don't know what would have caused that, as I have never used this valve before. Anyway, when I peer into the hole created by the now removed valve, it looks like there is a piece of plastic stuck up in there. Now I have to try to find a way to extract that and get a new valve. Getting a new valve won't be a big problem, there are a few marine service/parts places around here. I just wonder if I can get the old chunk out of there without buggering up something in there. Any suggestions??
