  #1
Old July 22nd, 2007, 10:34 PM
Singing Boat Guy Singing Boat Guy is offline
Default Help Mercury 90 hp won't start
Hello Everyone,
I just purchased a 79 16 foot glasply with a 78 mercury 90 hp 3 cyl 2 stroke (serial # 5714660) on it. The boat was disassembled and in mid project when I got it, so I kinda working at it by the seat of my pants. The biggest problem I am having at this moment is I can't get the motor to run. It cranks over and will sometimes catch briefly, then die. It is getting gas, but strangely it is leaking from the carbs, the bottom one mainly, and then pools and comes out the bottom cover. Is this normal? I know I have been working it trying to start it.
I bought a new 650 cranking amp battery for it, but wonder if this is enough battery for the motor? I have checked that it is getting spark to the plugs, have pulled 5 of the 6 plugs to clean them up.
The weirdest thing about trying to start it is that mostly it only allows you to spin it quickly before it shuts down the ignition on its own, so the key is still turned and held in start. Sometime it will let you really crank her, then it shut it down. Is this somekind of safety feature so you don't burn out the starter?
I would appreciate any help and ideas that anyone has.
Thanks in advance,
Chris
  #2
Old July 22nd, 2007, 10:48 PM
Plainsman's Avatar
Plainsman Plainsman is offline
Default Re: Help Mercury 90 hp won't start
Welcome to iboats Chris!
See if this will help you:
http://forums.iboats.com/showthread.php?t=158071
__________________
Rest in Peace Spinner
1978 SSV-176 Glastron with a 1976 115 hp model 1150 , 1972 Mercury115 hp
Your friend,your partner, your defender,your dog.You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion....by E.F. Henry
I am NOT a mechanic, but I did stay at a Holiday Inn Express
  #3
Old July 23rd, 2007, 03:50 AM
Thanks for the reply Plainsman! I will get a volt meter and start checking some of that stuff. It is almost like it is not getting gas, yet it was dripping out of the bottom carb. I will try it again tomorrow as I am sure it got flooded. ( I hope that is why)
__________________
1989 17'.5" Edson Sunbyrd with a '91 225 hp Suzuki Outboard.
  #4
Old July 23rd, 2007, 11:50 AM
Chris1956 Chris1956 is offline
Cool Re: Help Mercury 90 hp won't start
Chris, In 1978 the Merc 90HP motors were inline sixes with three carbs. They also had a distributor. If your carbs are leaking fuel when the motor is in the upright (running) position, your carb floats are set incorectly, the inlet needle and seat are leaking or your floats are defective. On that model, the original floats were made of hard foam. The replacement floats were made of hard plastic. Each float had a small spring on the top which pushed on the compound lever to close the inlet needle.
Sounds like your carbs to me, but check to see that you have spark on all cylinders, and no arcing to ground is occuring.
  #5
Old July 23rd, 2007, 02:25 PM
Chris1956, thanks for that tip. This is getting into some really unkown territory for me, as I have never done anything with carbs before. What is arcing to ground and how can I check for it? I am familiar with checking plugs and wires for spark, just never even heard the term arcing to ground before.
Thanks for the help.
Chris
__________________
  #6
Old July 27th, 2007, 05:44 PM
Default Re: Help Mercury 90 hp prop won't spin
Okay got the motor running. It turned out to be the ignition switch. Now it runs, but I can't get it to go into gear, neither forward or reverse. I am going to guess that it is in the controller. As mentioned above I am putting this boat back together, as it was all apart when I bought it. I put the throttle cables into their correct places I hope. There are two wires that come off the front of the controller out of a seperate harness that is marked trim, tach and something else. There are only two wires that can be attached to anything, as the others fold back to the controller. What do these connect to and do they have to be connected?
I am almost ready to put it in the water and try it out.. Please help.,
Thanks,
Chris
__________________
  #7
Old July 27th, 2007, 06:55 PM
Here are some picture of the controller and cables
http://www.facebook.com/photo.php?pi...610353351&prev
http://www.facebook.com/photo.php?pi...3&id=610353351
http://www.facebook.com/photo.php?pi...4&id=610353351
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
95 Mercury 150 will not start bassfishinggal Mercury & Mariner Outboards 3 October 4th, 2004 10:20 AM
Problem, Mercury 500, start at home, wonÂ’t start at lake Nandy Mercury & Mariner Outboards 13 May 22nd, 2004 12:53 AM
Mercury 5000, start at home, wonÂ’t start at lake. Nandy Mercury & Mariner Outboards 18 April 17th, 2004 01:02 AM
50 Mercury Start but hard to stay start. mann Mercury & Mariner Outboards 1 July 26th, 2002 02:26 PM
Mercury 225 won't start seatoy Mercury & Mariner Outboards 4 June 16th, 2002 01:54 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
