I have a 97 VOLVO PENTA 5.7 GSI PLKD TB EFI setup. I bought this since I thought it would be more reliable than carburetion.
Anyway, I am troubleshooting a stalling issue and I am trying to understand this crazy EFI setup.
My main question is why 2 pumps and a reservoir?
Low pressure pump feeds reservoir, High Pressure pump draws from reservoir (which has a mechanical float an valve) and feeds injectors. ECU (computer) tells injectors to open, and how much too open. At a minimum, there has got to be a throttle position sensor although I have not found one listed. Must also have a ignition module to tell computer RPMS. In my opinion this setup has too many points of failure. As far as I can see the reservoir has water circulating through it to keep the fuel cool. Is that it?s main purpose or is there something more to it? My thought is why couldn't the 2 pumps and reservoir be replaced by one high pressure pump? I think the chances of vapor lock would be really minimal and the risk is lower than the risk of one the components (extra pump, reservoir including a mechanical float and valve) in the OEM setup failing. Am I way off here?? Not really considering the swap, just trying to understand.
