  #1
Old July 21st, 2007, 06:32 PM
lilngineer lilngineer is offline
Default Mercury (Force) Sport Jet 90 Cracked Cylinder Block Causes
Hi,
I have recently purchased a 1994 Sea Rayder with a Mercury [Force] Sport Jet 90. The history is that the previous owner was running the boat on the lake one day and suddenly had a loss of power and it was brought in. The engine was found to have low compression in the bottom cylinder and needs to be rebuilt due to a damaged piston [see pic] and a crack in the cylinder block near a port.
I plan on performing the rebuild shortly, but my question is what likely caused the crack? I spoke with the tech who examined the engine and he stated that the bolts for a cover 90 degrees to the cylinders (transfer port cover?) were loose [see pic]. If this is true, what likely caused this condition? Whatever the true problem was, I would like to ensure that the problem does not return with the rebuilt engine.
Any opinions/help is greatly appreciated!
Thanks,
Jason
  #2
Old July 21st, 2007, 06:36 PM
Default Re: Mercury (Force) Sport Jet 90 Cracked Cylinder Block Causes
Also, one other thing...
If a suitable replacement block cannot be easily found as Mercury no longer supports the Force engines, can this block be welded? Isn't it cast aluminum?
Recommendations?
  #3
Old July 21st, 2007, 11:00 PM
Frank Acampora's Avatar
Frank Acampora Frank Acampora is offline
The bolts are on the transfer cover. this covers the intake side of the block. Loose bolts may cause a loss of power depending on how loose. If it is the original engine with factory gaskets, those gaskets are self gluing and tend to seal even with loose cover bolts. This would not have caused a cracked block. When you dis-assemble toe block, show some photos. That may be a stock 85-90 sitting on a jet adapter. If that's the case, you could replace the block with a regular outboard block.
I couldn't see the crack you were writing about, however, if it is cracked at the port and the crack goes through the aluminum and the steel liner, forget about it. It will be more trouble than it's worth to repair it.
  #4
Old July 22nd, 2007, 01:58 PM
I will post some additional pics once I have the engine torn down. Any additional thoughts on what might have actually caused the crack in the block if its not the transfer ports cover bolts?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 Sport Jet 90 Cracked Cylinder Block Causes lilngineer Mercury & Mariner Outboards 0 July 21st, 2007 06:29 PM
1992 omc cobra 3.0 cracked block, can i use a chevy 2.5 auto block??? sandman44andahalf Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 13 June 19th, 2006 05:20 AM
my 1997 Force 120 engine block is cracked... :( JamesGY Force & Chrysler Outboards 26 January 1st, 2006 01:07 PM
1979 Galaxy cracked block mercury/gm 305 matt wise Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 February 26th, 2003 02:58 PM
Mercury Sport Jet 90 (Force) Ignition Timing. SB Mercury & Mariner Outboards 5 August 18th, 2002 07:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
