  #1
Old July 21st, 2007, 03:28 PM
usfarmparts usfarmparts is offline
Default Mariner 40 HP cooling problem
Engine not cooling, prior symptoms were water from the upper discharge when cranking over but not running, as soon as engine starts water is lost at the upper discharge. This is a through prop exhaust. Removed and replace water pump with standard kit, still does the same. Double checked the tube to pump fit and I believe it is sealing. Connected hose to water tube with lower unit off and started. Cooled fine at very little water pressure form hose. Head temp as cold as the well water it came from. What am I missing. I repair tractor but not much on this. I thought if water supplied from the hose cools it then if the pump is doing it's job is would be the same?
Thanks
  #2
Old July 21st, 2007, 09:20 PM
Laddies Laddies is offline
Default Re: Mariner 40 HP cooling problem
What years is your engine
  #3
Old July 22nd, 2007, 02:10 PM
I believe 1987, Model 40ELTO Code 6E9-L and Serial is 501426, w\ oil injection.
Thanks
Randy
  #4
Old July 22nd, 2007, 06:06 PM
Randy, first let me say I have never worked on a japanize mariner in my life so I had to go to the parts book to look at a picture to se what you have got and if you have already installed a kit I would look for a leak on the vacume side of the pump--a crack in the area between the exhaust and water pickup in the housing, so merc you need to seal the area between the w/pump plates and the exhaust tube with the silcone. Sorry I should have told you first then I get a problem unit to make sure the pump is working I take a 3/8 drive 3/8 allen wrench and attach it to the drive shaft with a piece of hose and use a electric drill to turn the shaft, then submerge the pump in a water tank to ck the pump. Once pumping slowly lift the unit, it should continue to till the water intakes come out of the water or the vacume leak comes out of the water. Hope this helps - Bob
  #5
Old July 22nd, 2007, 09:51 PM
Thank you for the direction.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 1998 cooling JHM Mercury & Mariner Outboards 4 April 28th, 2007 07:37 PM
15hp mariner cooling meh Mercury & Mariner Outboards 1 September 27th, 2004 09:28 PM
Mariner 15 cooling question gittygoat Mercury & Mariner Outboards 1 August 23rd, 2003 12:03 AM
mariner 30hp cooling mrfixit_59 Mercury & Mariner Outboards 0 June 21st, 2003 07:19 AM
cooling problem for mariner canbey Mercury & Mariner Outboards 4 April 4th, 2003 10:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
