  #1
Old July 21st, 2007, 12:09 AM
Gr8Jpn Gr8Jpn is offline
Default Mariner 40HP ignition switch which wires?
Well I am pretty mechanically inclined.. but I have no idea what the heck I have got..
1986 Mariner 40HP EL ID NO 422195 2 Cyl.
I have a 7 pin wiring harness.
I think I have a Yamaha made outboard.. but I dunno.
I have the same problem as a lot of the threads, need help wiring my new ignition switch.
Need to replace the ignition switch.. (the guy before has forced the key in upside down so many times that I have to fiddle around and get the key in just the right way.. in the right spot otherwise no dice)
The old switch has 6 posts.. and the standard letters that are all over advice in this Forum: B, M, A, M, C, S
The new switch is Quicksilver part # 54211T, and only has 5 posts.. and different letters.
Specifically: B, E, A, D, F
I thought the Marine part store had sold me the wrong switch.. but scanning the web I see that this is the Quicksilver replacement without the push to choke option.. (I guess I could always add a toggle for the choke if I wanted)
I am at a loss as to which wire goes where.. any help? PLEASE?
  #2
Old July 21st, 2007, 12:28 PM
bhile's Avatar
bhile bhile is offline
Default Re: Mariner 40HP ignition switch which wires?
You have the wrong switch. You need the 2 M connections to turn the motor off. I suspect that the one you have is for an I/O
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #3
Old July 21st, 2007, 01:11 PM
roscoe's Avatar
roscoe roscoe is offline
yep, return the switch.
  #4
Old July 21st, 2007, 01:31 PM
Silvertip Silvertip is offline
You need the push-to-choke style switch. Without it you have no way of choking a cold engine.
  #5
Old July 22nd, 2007, 10:01 AM
Hey thanks for your help!
Per the Mercury Express parts website the 5 lug was the correct switch.. The original was discontinued... and with a simple Ohms test I figured out what the lugs were for and how I could have made it work..
But I just did not want to then hard wire a choke and all that jazz..
So I found a 6 lug - push to choke generic model at a local Boaters World for $16.99 (The Mercury 5 lug was $34.95)
So I saved time and MONEY by getting a correct switch.
Thanks for the help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
ignition switch 40hp mariner/sweetwater pontoon tjd579 Mercury & Mariner Outboards 4 August 4th, 2007 04:11 PM
1979 Mercury 40HP - Ignition Switch Box, Replacing wires... TheChad Mercury & Mariner Outboards 24 July 26th, 2007 01:27 AM
Ignition switch wires question. Scaaty Johnson & Evinrude Outboards 2 March 29th, 2007 04:19 AM
Wires to ignition switch danny gigli Johnson & Evinrude Outboards 3 April 23rd, 2006 11:16 AM
Mariner 40HP Ignition Switch Xcusme Mercury & Mariner Outboards 2 October 28th, 2004 06:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
