Hi guys:
Just scored a nice Fleetwin 7.5 w/ original tank. It runs well but was gushing water out of the cowling as the lower freeze plug on the head was dislodged.
I removed the cylinder head cuz it looked easier than removing the power head (not sure if this is really the case or not but the head was easy enough to get off). I was able to get the freeze plug though I had to order the head gasket.
Here are the questions:
1)What is proper cylinder head torque and tightening pattern?
2) What sort of locktite should be used? (it looked like red had been used previously).
3) I'll clean up the combustion chambers and piston tops while it's apart but any other "to dos" before it goes back together?
Thanks in advance,
=CPW=
(Outboard Rookie)
Thanks in advance,
=CPW=
(Outboard Rookie)
