jimMayor007
- Jun 13, 2007
- 2
What are some common signs that it may be time for a new propeller?
Your boat takes longer to get on plane than it used to. It uses more fuel. It doesn?t seem to run as fast as it did when it was new. If your boat feels sluggish, one of the first things you should check is your propeller. Is it showing signs of wear and tear? Does it have more than its share of nicks, dings and missing paint? These symptoms can accumulate and significantly impair the performance of a perfectly good engine.
Important Information on Boat propellers
