Re: Speeditwin Shut off switch
Welcome to iboats.
Typically, on older magneto ignition motors, run 2 wires, one from each point set down through the armature plate to a normally open switch. When the switch is thrown, both ignition point sets are grounded through each other killing the spark to the plugs. Use crimp-on ring terminal ends at the point sets and a rubber grommet through the armature plate to prevent shorting. Stranded wire is a must in this application as it has to flex with the motion of the armature plate.
