  #1
Old July 20th, 2007, 02:26 AM
flandreau flandreau is offline
Angry 79 25hp evinrude bendix gear slips?
my bendix gear sometimes will not engage flywheel and engine wont start, teeth are not that worn....a friend mentioned i need to remove some shims
any ideas out there?.....where are the shims located?
thanks......TEDDYFIVE
  #2
Old July 20th, 2007, 03:23 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 79 25hp evinrude bendix gear slips?
try putting a little bit of 3 in 1 oil on the shaft. the bendix is inertia driven to raise up and engage the flywheel. here is a blurb on starter problems:
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'82 20 hp Evinrude - slips out of gear dhwright Johnson & Evinrude Outboards 0 August 9th, 2006 05:46 PM
1989 evinrude 50 slips out of gear HELP TPyles Johnson & Evinrude Outboards 1 June 19th, 2006 06:46 PM
85hp evinrude slips out of gear redneckcuz Johnson & Evinrude Outboards 3 April 21st, 2004 07:08 PM
9hp sea King Starter Bendix Gear blackbear98 Other Outboard Brands 2 July 9th, 2003 10:46 AM
87 25hp evinrude bendix problem Trent Johnson & Evinrude Outboards 9 March 4th, 2002 11:46 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
